View Full Version : Error Code how to reset transfer belt message on c250
tmaze01
02-09-2011, 09:29 AM
Hi,
does anyone know the correct procedure on reseting the transfer belt message on a konica minolta c250 (or where the fuse is located inside belt assy ) this will be the 1st reset on this belt/ machine only has 134k copies, as always your help is appreciated.
thanks
taylor
bizhub1
02-09-2011, 11:36 AM
The location of the fuse is by the front side handle of the belt. You will see a little black cover with contacts on it. Remove that cover and the fuse is inside. I usually take the plate of the top of the belt with the sep claw on it first.
tmaze01
02-09-2011, 06:18 PM
Thank you very much , i appreciate it
