View Full Version : Error Code di 2510 don`t boot up
boanda
02-09-2011, 10:32 AM
I got secondhand di 2510 and on every start up I get message on screen "DON`T BOOT UP"
also, i can't make it to scan, only can print and copy
In service book writes that the machine has SU2 and FAX unit?, but PS drivers want work too
xeroprint
02-09-2011, 08:43 PM
REmove scan and print card. Check it. Rewrite firmware.
Darren King
02-09-2011, 09:36 PM
The only time I have seen "don't boot up" on one of these machines is when the CF card is not in.
Hope this helps
Darren
xeroprint
02-09-2011, 09:43 PM
You must insert CF card.
aesthetics1
02-10-2011, 12:35 AM
This machine won't print with a PostScript driver unless it has the PostScript Interpreter option. Try the PCL driver and you will probably find that it works fine.
Don't Boot Up! messages can be attributed to dead/dying SU-2 scan chips, dead/dying PCL/MP chips, or chips put in the wrong slot (ie reversed,) as well as problems with the device's firmware.
boanda
02-10-2011, 07:33 AM
CF card is in, I must shut it down and up,every morning,few times then the machine works fine all day, coping and printing with PCL
When I try to print with PS, I saw that the document has been spooled but want to print, and not showing any error.
Ill try to find some old SU2/3 to replace with existing one and flush the machine to see what happens.
TY all for big help, i suspect on su2 but,honestly, practically this is the first time that I have this kind of problem and I really appreciate
yours help.
Ill let u know what solved the problem
aleksander
02-14-2011, 03:06 AM
check the firmware or re-format your CF card.
boanda
02-14-2011, 07:38 AM
CF card replaced and new firmware added and all working fine!
TY all for help!
