Hello,
we have a Bizhub C252 machine which following to her transportation from one office to the other is now showing some bad alignment of black color (rotated of less than 1mm) towards the other CYM colors. In other words, if you look at a text printed page in green color (for example) you can see that the centre of the page is ok, but the upper and lower part is twisted (theu pper part on the left and the lower on the right).
I saw on the service manual of the C350 a very helpful option called Color Shift Correction, which is not present in the C252. This function allow to "rotate" the black color according two direction (clockwise or counterclockwise). It would definitely fix our machines....
Do you know any similar function for the C252 or alternatively do you think it is possible to find the above function on updated firmware/s (if any)???
Thanks in advance for you suggestions/comments.
Best regards
Best regards
