jmaister
02-18-2011, 02:42 AM
Good day folks,
I've ran into few cases where the machine jams on double sided (copy/print) and had no idea where to start. I noted something worth asking.
symptom: (orientation is portrait)
1. print out is wrinkled severely, machine jams(looks like it clipped on something)
2. paper jam, open panel and see paper folded between fuser roller.
Observation.
1. On the second pass, corner of the lead edge went behind the fuser spur or actually went into the thin gap between fuser unit and t unit.
2. On the second pass, the entire lead edge went into the gap betwn fuser unit and t unit, and the sticky roller grabbed the bulge and pull it up. (this i actually saw)
I did notice the T unit had no spurs(plastic spike wheels on metal clip, no part #) on the outside and changed them with ones that do, and problems went away. It made sense for the spurs to be there but I couldnt explain why there are ones without.
Did anyone encouter this before? Did replacing else where fix the problem? Good effort but no, or good job young man?
I couldnt find any thing on KMA connect to officially back up my theory, is there anything?
Observation.
