View Full Version : how do I print double sided with Konica Minolta Di2510???
attilakis
02-21-2011, 05:30 AM
I have a problem with printing double sided with konica minolta di2510. When I use the copy function, the double sided option is available, but when I print from PC, in the properties window of the printer, the "duplex/booklet" option is in "off" position, and the field is gray so I cannot select "on". Any suggestions?
aleksander
02-21-2011, 07:57 AM
The problem is in your printer driver. Go to Printers & Faxes, right click on Minolta Di2510 and choose properties. Go to tab Device option setting. You must add the AD-16 (Duplex unit). It will help you.
attilakis
02-21-2011, 05:39 PM
Thank a lot! It worked!!!
