dickierock
02-21-2011, 09:38 AM
Hi all,
We only have 2 of these machines in the field so our expierience of them is limited.I was hoping to rely a bit on the knowledge of you guys before I completly dismantle this machine.
So the problem I have is a P27 error code causing very light images.The service manual refers it as 2nd Image Transfer ATVC failure.The manual suggests replacing the transfer belt unit (done) and then checking the contacts (done,I think!),after that the manual points to the hv board and after that the main board.I am reluctant to start stripping out the machine until I get the opinions of you guys with more expierience on these machines than me.Hopefully it is something that can be rectified easily.Many thanks in advance.
