View Full Version : Samsung SCX 6345 Toner Suppl Error
iscott
02-23-2011, 02:15 PM
Customer Put in new Toner and 1 day later got the Toner Supply Error message
This is a Factory Cartridge.......
Tried another toner and got same message, also rebooted no change
blackcat4866
02-23-2011, 02:17 PM
I'd take a look at the drive coupler in the back of the machine. =^..^=
iscott
02-23-2011, 06:40 PM
Motor Running fine from test mode could not see coupler but the sprocket that spins the toner augar as turning
Jeff M.
03-05-2011, 12:03 PM
Make sure the coupler moves in and out freely. Just saw a bulletin for the 6555 on this problem, says the coupler might swell and stick and not mate with the cartridge. Hope this helps. Regards... Jeff M.
blackcat4866
03-05-2011, 03:04 PM
Yeah, I just saw that same bulletin. Apparently, like the Sharp AR-160, the plastic toner motor shaft breaks but not completely through, allowing the shaft to twist and bind the spring loaded coupler. =^..^=
Canuck
06-09-2011, 07:02 PM
Replace the coupling, I've had to change many.Part number JC97-02681A (MEA UNIT-GEAR SUPPLY)
copytechman
06-09-2011, 07:26 PM
Yup, been there, done that! Seconding this!
Regards!
A.
bdcrandall13
09-21-2011, 05:00 PM
Also, make sure it is the correct toner. A 6555 cartridge CAN fit in a 6345 but will not work.
AN36XA
07-19-2012, 07:36 PM
Are you talked about toner cartridge or drum cartridge?
I have problems with some new (85%) drum cartridges SCX-R6345A, have same ''toner supply error''
AN36XA
07-20-2012, 06:51 PM
Can you share that bulletin please on pm? here in europe gspn i cant find that bulletin
