bizhub c450 blue ghost on the paper
  • jzheld
    • Sep 2010
    • 162
    [Misc] bizhub c450 blue ghost on the paper
    Just got a used c450, everything works fine, just have a blue ghost on the left side of any image. I had that problem with c500, it was because of the shipping screws, but not sure about that.
  • stan780953
    • Feb 2011
    • 47
    unfortunately it looks like you are going to need a new cyan imaging unit.
    • stevelau
      • Jul 2010
      • 21
      Try printing out the test print of CMYK and see if all colors are having this problem.
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        Problem is very likely to do with the fusing unit. Is this thick paper stock? If so, what is the weight of the paper? The machine maximum is 67 lb (thick 4). Using weights exceeding this value will leave a latent image on the fuser roller, due to insufficient fusing.
        Transfer belt cleaning can sometimes also give issue if the belt cleaning process is insufficient, or in some cases, disabled. In tech rep, image process adjustment, transfer belt, adjust the cleaning bias to mode 4 (maximum) in both fields.
        In the 'auto cleaning' section, ensure it is enabled.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
