View Full Version : anyone know if there is a sub part for this sharp part number RPLU-0008QSZ1??
kvilaysing
02-28-2011, 10:23 PM
I can't seem to find it anywhere... Help anyone.
Thanks in advance!
ZOOTECH
02-28-2011, 10:42 PM
Thanks in advance!
There is no sub part number and I see it is currently unavailable; I don't know if it will work for you but you might try RPLU-0008QSZZ.
kvilaysing
02-28-2011, 10:54 PM
Thanks for the quick reply... ZOOTECH.
RPLU-0008QSZ1 is a paper stop solenoid and RPLU-0008QSZZ is a PLUNGER.. that can't possible be the same.. is it?
ZOOTECH
02-28-2011, 11:06 PM
??? Well, the naming of parts is not always precise and the "plunger" is more expensive than the "solenoid, ps"??? So I cannot say for sure that they are the same.
kvilaysing
02-28-2011, 11:34 PM
Yeah, you're right! I think I might go ahead and take that risk and order it. who knows it might just do that job.
Thanks for all your help! =)
blackcat4866
03-01-2011, 01:00 AM
That's the way Sharp updates part numbers RPLU-0008QSZZ updates to RPLU-0008QSZ1 (and if it updated again it would be RPLU-0008QSZ2). The paper stop solenoid is the "registration" solenoid, and I have replaced a few of those over the years.
Like Zootech says, disregard the naming convention. The exposure lamp has been called a "lump" unit, and the developer drive called "deveroper" drive, and calibration called "carbeuration". Sharp translators faired Engrish crass. =^..^=
kvilaysing
03-01-2011, 04:36 PM
All were great info! Thank you for all the helpful information. I appreciate it!
kvilaysing
03-01-2011, 05:07 PM
I have another question... RPLU-0008QSZ1 is for a AR-M207... and I found RPLU-0008QSZZ on a AR-M160 service manual. Do you know if those two machine is compatible as for parts? in other words do you think RPLU-0008QSZZ would work on a AR-M207?
Thank you again!
ZOOTECH
03-01-2011, 10:49 PM
Thank you again!
My parts guide shows the ARM160 has the RPLU-0008QSZ1 as does the ARM207. The ARM160 is the same for most parts as the ARM205; the ARM207 is the same for most parts as the ARM162. Some parts are interchangeable across the Pegasus family.
blackcat4866
03-02-2011, 12:57 AM
Most mechanical parts will be the same. Electronics, like boards and motors will be different. =^..^=
