KHAN
07-09-2007, 04:40 AM
Hi,
TWO MONTHS AGO I REPLACE DRUM,BLADE AND DEVELOPER IN THE Di 470 COPIER, AFTER MAKING 10000 COPIES I GET COPY WITH BACK GROUND LIKE BOIS BROBLUM, I CHECKED EVERY THING BUT VAIN,THEN I PUT THE OLD DRUM IN THE COPIER IT WORKS GOOD,
THEN I TRY THE NEW DRUM AN OTHER COPIER THERE ALSO I GET THE SAME RESULT WITH DARK BACK GROUND,THIS A OPC DRUM I CHANGE THE VG VALUE AND ATDC ,REFINE ,BUT STILL WITH DARK BACK GROUND. SO I NEED ANY SUGGESTION ?
THANKS,
THANKS,
