Bizhub C253 K IU Problem
  • minimerlin
    • 851
    I am having a problem with the Black image units of this machine causing toner/dev to build up on top of the drum at the front of the unit (just 3inch wide.
    Just wondered if anyone has had similar fault. I have replaced the iu a week ago after the origional one gave this fault, now I have to go back for the same happening again.
    All units are inlife and not chipped. Seems like too much toner/dev at the front of the unit causes a wave effect which pulls the spillage with the rotation of the drum? I will try to get a picture tomorrow as it is hard to describe what is happening. Copy/ print quality is ok on the rest of the page just smudging effect caused by black at the front of the machine. (Looks a bit like the C550/650 K units do at the rear but this is the other way round!) IU is fully home and all connections are clean.
    Any Ideas?
    Please do not PM me without asking first.
  • konikilla
    • Nov 2008
    • 43
    Have you checked the machine with a spirit level?
    • minimerlin
      • 851
      Machine is level in both directions. Fault started a few weeks ago. Last week I find that the problem only occurs when running Thick stock..ie thick1 upwards, the thicker the stock, the worse the fault gets!
      • konikilla
        • Nov 2008
        • 43
        It's sounds very weird. I would take a look at the secondary transfer if it is only happening with heavy stock. I would also the transfer cleaning blade assy. and check your laser unit is clean or just swap it with the one of the others.
        • minimerlin
          • 851
          I agree its a weird one, laser is clean, and the transfer all seems fine, am going to swap out the HV and connectors in case we have a corrosion problem. It has been suggested on another post to adjust the dev blade gap but that seems rather drastic! I will let you know my findings when I revisit next week..my brain needs a reboot I think! Thanks for your input, any assistance in this one is welcome.
          • minimerlin
            • 851
            Went back to the machine today and did the dev blade tweek as suggested....ran 400 prints on thick 3, 2 & 1
            , no problem! I hope that is the fix.
