View Full Version : KM C360 problem of graddation
karim-tech
03-07-2011, 07:46 PM
i change a black image unit and when i want to perform the graddation adjust
i can't go on normaly i just choose the paper A3 or A4 and print or copy then i click on start but now all of theme was blocked i can't click on and i have a P9,P21 message
thanx for your help
minimerlin
03-07-2011, 08:23 PM
thanx for your helpThe machine will not allow grad adjust until you sort out the cause of the codes P9 &P21. P9 is for the K unit. Did you change the drum or the dev unit?
karim-tech
03-07-2011, 09:03 PM
i change the black dev unit and the code P9 remind on
minimerlin
03-07-2011, 09:07 PM
Check that the unit actually turns! Sounds like it is too tight, take it out and give it a shake from end to end then try to turn it by hand.
karim-tech
03-07-2011, 09:10 PM
ok thanx it's so graceful i will tell the result
