View Full Version : BH-60/750 pulling DV
SKTeK315
03-08-2011, 12:10 PM
Hi everybody. Got a 600 pulling a little bit of DV with each copy or print. Goes through transfer/transport unit & down into duplex, making double sided Z-fold & misalign in the stapling. Could it be DV bias or any of the drum charges, like transfer AC ? If so, what should the drum charges values be ? I set DV bias at 184 to 204.
Would appreciate any help. Tnx.
CraigW
03-08-2011, 01:01 PM
Check the operation of the PCL lamps.
SKTeK315
03-08-2011, 01:09 PM
Ok. Anything else ? Also what should the bias & AC transfer be ?
CraigW
03-08-2011, 02:36 PM
As far as the adjustments... are the default values listed if you print the adjustments list ?? (don't have one,only mgmt list handy)
I would take them back to original value if possible.
Downunder
03-10-2011, 04:38 AM
Need to know bit of history. How many clicks on copier. How many copies has the drum and dev achieved. Is transsep in good order. Little plastic/nylon spacers on top edges of transsep guide plate. Has the charge grid been cleaned, etc. Always a good idea to put settings back to factory settings. On the back end of the drum there is a voltage figure stamped, usualy around the 700 to 720 mark. Has the copier been set up to this value. Are you using KonicaMinolta toner and dev, etc, etc.
HuronMan
03-10-2011, 04:07 PM
Is it only on the front side of the copies? Big pile in f. of t/s corona out to the exit tray?
tech51
03-10-2011, 05:57 PM
You will need to replace the drum/developer and possibly the t/s/unit. Clean everything and set the machine up by the book. Also check your fuser rollers, they may have been damaged as the dev passed through the fuser
Darren King
03-11-2011, 07:16 PM
I have had this problem a lot on these machines. It is almost always a dirty charge grid causing it. Try cleaning the grid, if that doesn't work replace it.
Hope this helps
Darren
