View Full Version : image problem
jokacross
03-10-2011, 12:39 PM
Hello I have a c450. And here it is the problem
I made the Image stabilization+Initialize and the first print become like this:
8822
After 16 prints looks like this:
8825
Then I made the gradations adjustments the 3 of them and the first print become like this:
8823
and after 16 prints looks like this:
8824
The original doc is this:
8826
What is this?
One mor thing in the gradation adjust the Conv. Value I cant never get the Right values! In the tree of them
minimerlin
03-10-2011, 10:01 PM
Is this the same fault from a week ago? Are the image units chipped? Is the toner OEM? Has the optics been cleaned? You need to do toner add before you do reset and stabilization followed by the grad adjustment. Make sure that the image that is printed (for the adjustment scan) is of good quality or you are wasting your time! When you have got the settings witin the specs switch off the unit and power up again. Do a test printout from the user mode. If your copy/print quality goes bad after a few copies I suspect a stabilizer problem or old IUs.
jokacross
03-11-2011, 09:42 AM
ok I gona try that and I tell something thanks!
Zeldaman
03-11-2011, 11:50 AM
Hi there!
I´ve had asimilar problem but the customer uses no original KM-toner and the transferbandunit was to old (not by prints but time!).
With the new transferunit it became better odd the OEM-toner.
Greetings....
