need Bizhub 600 firmware.
  • mrchoc
    • Oct 2008
    • 10
    hello,
    I have a problem with my copier bizhub600, photocopying works fine but when I try to get into the menus the machine displays "warming up please wait"and it remains like this until I turn it off ,I think I need firmware to reset the machine, otherwise if there is any other solution please help me.
    thank you in advance
  • mrwho
    Major Asshole!
    • 4299
    Originally posted by mrchoc
    hello,
    Is the drum unit and its sensors clean?
    Mascan42
    Ibid
    • mrchoc
      • Oct 2008
      • 10
      yes , it is clean , i also have a remarque when the machine is turned off for a long time , it works fine when i turn it on and print as much as i want , the toner cartridge is spinning but when turned off , and turned on right after it wont work . the test mode works in administrator mode
      thank you
      • RockETop
        Curmudgeon at large
        • Apr 2007
        • 171
        I would try a LVPS first.
        • mrchoc
          • Oct 2008
          • 10
          the problem is the toner, I got a new original cartridge, and it works very well. thank you
          • mrwho
            Major Asshole!
            • 4299
            Thank you for coming back with the solution - it will no doubt help other with the same problem.
            Reps to you!
            Mascan42
            Ibid
