View Full Version : Bizhub 250
ronald2020
03-13-2011, 02:47 PM
Hi u all,
need help with a bizhub250. I work on Ricoh machine's but have come across this 250 it's displaying the following:
!*! Abort !*!
code =0x00900000
tsk name =tRT16000
tskid =0x00003e80
SP =0x8962bd30
ra =0x812243d8
build_2591b.060719
I've replaced the fuser unit, drum unit, development unit i changed these cause they needed replacement & swapped the main board when it was showing the above msg i do not have any technical manuals on km's by the way working on it cause everyone else in our little town has failed to get it right. Your assistance would be greatly appreciated
konikilla
03-13-2011, 11:51 PM
I haven't seen this code and cant find it, but it's probably a
Failed MFBS and/or MEMS.
First upgrade the firmware to the latest version.
Then check if DHCP is being used when
the machine is set to manual IP addressing.
Lastly clean the contacts of the memory sticks.
Other than that you are looking at new memory
or a new MFBS board.
Zesti
03-22-2011, 02:49 PM
G3 device control system failure 0x00900000 to 0x009fffff
MFBS Board, FAX Board, Memory Board*
Try removing fax board.
ronald2020
03-23-2011, 11:28 AM
Thanx guys managed to get it going now working like a charm now fault was the fax board
aleksander
03-28-2011, 05:23 AM
Hi u all,
!*! Abort !*!
code =0x00900000
tsk name =tRT16000
tskid =0x00003e80
SP =0x8962bd30
ra =0x812243d8
build_2591b.060719
Try to replace your MFBS.
aleksander
03-28-2011, 05:29 AM
Hi u all,
!*! Abort !*!
code =0x00900000
tsk name =tRT16000
tskid =0x00003e80
SP =0x8962bd30
ra =0x812243d8
build_2591b.060719
Hansoon
03-28-2011, 05:55 AM
Pssst....... Hey Aleksander:
Thanx guys managed to get it going now working like a charm now fault was the fax board :)
Hans
aleksander
03-28-2011, 06:50 AM
sorry...lol
thanks Hans
suso73os
03-28-2011, 09:02 AM
I had a similar problem and I solve it resetting fax parameters.
fishleg
03-28-2011, 11:10 PM
I hate these machines what a load of turd. Not sure what's worse the crazy error codes you get 10 seconds to write down or that bloody ne nor noise....
Hansoon
03-29-2011, 05:54 AM
:confused::confused::confused:
Hans
ddude
03-29-2011, 06:26 AM
HA!
Only from the (file corrupted) minds of MINOLTA.....
