View Full Version : Bizhub 250 again!
ronald2020
03-14-2011, 03:50 PM
Hi you'll,
It's me again, I managed to get past error fault that was showing on the machine, now I'm getting a constant paper jam just before the paper reaches the registration roller.
Konkiller thanx for the pointer decided to unplug the battery for a few minutes seemed to have cleared the problem. Any ideas would be helpful thank you'll.
fixthecopier
03-14-2011, 10:39 PM
First you check to see if it jams from the top tray or both. If both, change the reg clutch, if it just jams from the top tray, there are small white clutches beside the rollers, that will fail and if that does not do it, there is a clutch behind the top tray that just drives the top tray, change it.
