View Full Version : Error Code error code C-2801: Konica Minolta C6501
cmateus
03-14-2011, 03:57 PM
We have this error C-2801. We just checked so many things but the error persists and we can print only blank pages. Does anyone know how to fix this error?
Thanks,
CMateus
Christian_W
03-14-2011, 07:21 PM
Hello cmateus,
the error code C-2801 says, that the gamma correction in yellow is aborted.
The units in failure can be:
Printer Control Board PRCB
Developing unit /y
Gamma Sensor PS11
Christian
cmateus
03-15-2011, 11:29 AM
The original error was C-4520, but we deactivate the "color registration" via software and then this error C-2801 started to appear; we remember to activate again the color registration and now we get the error C-4520 everytime.
Thanks for your reply.
cmateus
pinoyprinter
03-15-2011, 11:51 AM
did u already clean the registration sensors in the color registration unit?
cmateus
03-17-2011, 03:38 PM
Yes. I am waiting for a main controller, perhaps this board will fix the problem.
thanks anyway.
cmateus
empiru
03-17-2011, 11:27 PM
Hi!
I had the same problem with the 4520 code. I suggest you activate the color registration, but don't let the machine do it when it starts - do it yourself. I mean, start the machine directly in service mode and do the Automatic Color Registration Adjustment.
When starting directly in service mode, the machine won't give you any C - codes. When the adjustment is done, verify that all the values in that table are close to 0. (if they are smaller than 1,5 - 2, you can turn off the machine, than back on and it won't give you the 4520 code again).
I hope this helps.
cmateus
03-18-2011, 12:38 PM
Ok. I will try that. IŽll let you know if it solve my problem.
thanks,
cmateus
cmateus
04-26-2011, 04:46 PM
It did not solve my problems. All values are close to 0.
bizhub1
04-26-2011, 09:34 PM
Did you inspect the transfer belt unit really good
cmateus
04-27-2011, 04:46 PM
Think will have to reinspect everything again in detail.
Deas
04-29-2011, 10:07 AM
I have also had these issues, but with magenta. So I just swaped the drum (DU-120C) and then it all started to work again. You can also try to just pick out and put in the drum again and see if that helps.
cmateus
05-02-2011, 05:53 PM
we replaced the complete transfer belt unit and the error 4520 is still there.
So, we can not find the problem, even after replacing almost everything.
Perhaps we should start all over again. Changing toners, develloper units, drums, mainboard, coronas, sensors, etc. But we did it already.
If someone has any idea that could help, we would appreciate it.
thanks
Herrmann
05-02-2011, 09:46 PM
start the box by entering directly into service mode. Then go Process Adjustment--->Drum Peculiarity Adjustment---->Automatic Gamma Adjustment
As soon, as the maschine starts and you hear the "beeping sound" as the corona sets in, open the front door, this force the mashine to stop immedeatly. Slide out the process unit and have a look at the Transfer Belt and the Drum Surfaces. Are there color marks at all? Is one color missing? Also check the Harness at the back of the process unit, sometimes some wires get trapped between process unit and main body
cmateus
05-03-2011, 11:16 AM
IŽll do it. Thanks
backspace
05-03-2011, 02:03 PM
i have same problem, check the transfer belt unit and cam on TBU, rotate the cam clockwise.
cmateus
05-04-2011, 12:25 PM
What do you mean by rotate the cam clockwise? We even try the complete TBU in another machine and it worked OK.
But thanks anyway.
engineer
06-21-2011, 03:59 PM
if error code appear shortly after power ON, it Failed HV/2. Reseat CN736 on the PRCB and CN737, CN738 and CN739 on HV/2. or Replace HV/2 (p/n A03U M404 00) as necessary.
