View Full Version : Miscellaneous Bizhub C252 developer/carrier
xsstaff
03-15-2011, 09:32 PM
Hello!
I've heard that there is a compatible developer from other machine from Konica Minolta. Can anyone tell me if it's true? Maybe someone tried and managed to use some compatible developer and tell me about this.
Thank you!
ni311
03-16-2011, 06:44 PM
What exactly did you hear that will work with Bizhub C252?
xsstaff
03-16-2011, 06:52 PM
I've heard that Image Unit developer can be replaced with some developer that is compatible from other machine type, but I don't know from what machine !
minimerlin
03-16-2011, 09:41 PM
I've heard that Image Unit developer can be replaced with some developer that is compatible from other machine type, but I don't know from what machine !Why would you want to change the developer? Are you wanting to rebuild the IU`s?
xsstaff
03-16-2011, 11:22 PM
Yes, I want to rebuild the IU's. I already used them 2-3 times their lifetime and the developer lost his properties...
johskar
03-17-2011, 02:59 PM
Bizhub C250 and C252 Imaging Units are identical, but from what I can recall you can't get the developer separately and why would you want to rebuild an IU that isn't made to be rebuilt?
xsstaff
03-17-2011, 03:05 PM
Well the answer to your question is very simple: I can't afford a new set of IU's now - with the economical crisis the business isn't going very well and I was wondering how can I reduce the costs. That's when I heard about the developer compatibility between 2 machines, but I don't know which developer is compatible with the Bizhub C250/252 developer. So any advice would be great.
Thank you.
DadO
03-17-2011, 10:29 PM
You can try bizhub 163 developer and mix it 3 times whit ink of Cyan,Magenta and Yellow . Reply on results :D :D
xsstaff
03-17-2011, 10:32 PM
The IU' are still working, but if nobody tried and have something that works for sure, I'll try it.
Hansoon
03-18-2011, 06:00 AM
"Ink"
Hans
ck1
03-19-2011, 05:44 AM
we have try comp. Dv , so far so good ....
xsstaff
03-19-2011, 10:41 AM
What kind of developer did you use?
