View Full Version : Reset Drum % - Konica C5501
bpifer15
03-16-2011, 08:40 PM
I just changed out my drums on my Konica C5501. How do I reset my %'s that are displayed under the Utility menu back to 0%?
mrwho
03-17-2011, 08:38 AM
In service mode, Counter Data -> Parts Counter -> Count of special parts.
But you also need to run the drum peculiarity adjustments - check the manual for the propper maintenance procedure.
bpifer15
03-17-2011, 01:28 PM
Forgive me for asking but, how do I get in Service mode?
mrwho
03-17-2011, 02:30 PM
You don't know? Well, this is going to be fun. Just remember that, without a service manual and proper training, there's a chance of causing serious harm to the machine.
With that disclaimer, to enter tech rep mode you must press Utility, and then press the keys STOP-0-0-STOP-0-1 in sequence.
Good luck!
bpifer15
03-17-2011, 03:39 PM
Perfect! That worked. My boss decided to cancel our Service contract and leave everything up to me! Cheap! The only thing I couldn't figure out was how to reset the %'s after installing new parts. Thank you again "mrwho". I greatly appreciated the help
mrwho
03-17-2011, 04:34 PM
Okay. But tell your boss that I believe it should be a crime to run such a machine without a service contract - it will probably cost him in the long run.
Cheers!
bpifer15
03-17-2011, 04:50 PM
My thoughts exactly. Unfortunately, I'm the one who has to worry about it! Thanks again. I'm sure you'll here from me again :p
ni311
03-17-2011, 04:58 PM
I'm just curious... Did you removed the locking screws on the new drums before installing?
bpifer15
03-17-2011, 08:19 PM
Yes, everything went well installing the new drums. I'm back up and running... till the next repair :)
