View Full Version : Please Help ICD 17
unvisible
03-17-2011, 08:44 AM
hi to all.
Please take a pic from REYB/PH ICP6 and PRCB ICP17 and Printer Control Board (PRCB).
My machine have a error c_4501 and i search in net and etc. but not find propert answer. i change ph unit but now i have this error.
thanks
unvisible
03-17-2011, 09:52 AM
i finde icp 6 on ph unit bord how i can test it
unvisible
03-18-2011, 03:31 PM
No body can help me to solve this problem (c-4501)???????
Brischaffer
03-18-2011, 03:53 PM
What kind of machine are you working on???
emujo
03-18-2011, 04:46 PM
ICPs are small resistors that protect the PWB from overcurrent if the load associated with it has an issue. You can check them by "OHMing". Just like a fuse. Problem is if they are open you have to replace the board anyway. If you have a blown ICP you should replace the componant it protects at the same time, if not, you will probably blow the ICP again. On the C650 series this indicates a problem with the REYB/PH. On the production print MFPs it also indicated a PH problem. Emujo
