View Full Version : Can't scan to SMB from vl4222
stub
03-18-2011, 05:23 AM
I have multiple vl4222 copiers at this location, but one of them will not scan to SMB. The rest do just fine. I tried to update the firmware but I get a write error with no code.
Any suggestions on what could resolve my issue.
emujo
03-18-2011, 04:53 PM
What is the vl4222? If it's a Bizhub 222, then you may want to check the s/n as there is a cut off as to which version of firmware you can update to. Putting ver 2 on a MFP below the cut off will damage the OACB. What is the code you get when scanning? Emujo
stub
03-18-2011, 05:00 PM
I don't get a code. When putting a stack of originals in the feeder and sending to a work station it feeds a couple of originals and then stops and the machine says that there was an error in sending. I cannot sent via e-mail either. I am leaning toward reloading the NVRAM.
emujo
03-18-2011, 11:10 PM
If it's a KM product there has to be an error code, it could be as simple as deleted by user, but it's there. Check the log history using the LCD screen as the web interface is vauge. Emujo
stub
04-01-2011, 05:25 AM
The problem was the CF card was corrupted. Reloaded the firmware on the card and it worked just fine.
ExXeroid
04-01-2011, 03:24 PM
VL4222 is an "OCE" device isnt it???
