View Full Version : Bizhub C353 boot up problem
AjitN
03-19-2011, 03:26 AM
Hi
I have one C353 which displays only Sand Glass after power ON. Machine rotates but nothing happens further.
Reloaded firmware still same symptons.
Any known solutions before testing MFP board, Power supply unit.
Thanks & Best Regards
Ajit
pinoyprinter
03-20-2011, 01:39 AM
i think its an nvram malfunction.
stevelau
03-20-2011, 09:56 AM
Try changing the NVRAM. If still cannot, try to flush out the firmware and reload.
bhangdu
03-20-2011, 11:36 PM
I had a same problem, i have run the nvram recovery special firmware on the machine
AjitN
03-21-2011, 03:22 AM
Thank you friends.
I do not have nvram recovery special firmware tool. Does it named as "A02E0Y0-F000-GCQ-J8_00_.EXE".
If this is the file I have it but if not, can anybody tell me where to find the same.
Best Regards & Thanks again
Ajit
bhangdu
03-21-2011, 07:30 AM
[Release version]
< C650/C550/C451/C353/C253/C203 jig firmware>
Model
Program Name
Ver.
Program File Name
Checksum
Note
bizhub C650
Jig firmware
GCQ-J8
A00H0Y0-F000-GCQ-J8(00).EXE
0E9A
bizhub C550
Jig firmware
GCQ-J8
A00J0Y0-F000-GCQ-J8(00).EXE
8E57
bizhub C451
Jig firmware
GCQ-J8
A00K0Y0-F000-GCQ-J8(00).EXE
7D69
bizhub C353
Jig firmware
GCQ-J8
A02E0Y0-F000-GCQ-J8(00).EXE
91B0
bizhub C253
Jig firmware
GDQ-J8
A02E0Y0-F000-GDQ-J8(00).EXE
9139
bizhub C203
Jig firmware
GEQ-J8
A02E0Y0-F000-GEQ-J8(00).EXE
AFA0
Cheers
Abhay
AjitN
03-22-2011, 04:14 AM
Hi
Problem is resolved by nvram initialization.
Thanks and best regards to all
Ajit
Mike Lee
04-18-2011, 04:56 PM
Ineo C253 planets showing.
Flashed firmware.
Tried Memory chips.
NVRAM ok.
MFP pcb changed.
Still same fault.
Changed PRCB PCB and flashed firmware again and now finally works !
bizpodcentre
11-03-2011, 09:17 AM
Hi,
I also have the same problem but on Konica Minolta Bizhub C253. Does anybody
have the NVRAM recovery file for bizhub C253? You can email the file to me
at bizpodcentre@yahoo.com
thanks
mervyn
11-03-2011, 01:13 PM
As previously ststed on various posts here , if you are a trained konica minolta tech you can get the firmware on the kmbs tech website , if not then call a trained tech . No one is going to e mail you the nvram recovery program , it is against kmbs policy .
ahson1989
11-21-2017, 09:55 AM
Hi. I need bizhub c 203 frimware. Also tell me how to upload the frimware. I m new in this . Thnx
