View Full Version : Bizhub 350 Printing Issue
goldencup
03-19-2011, 09:19 AM
Hi! i would like to ask, is there a way that i can make the Bizhub 350 to print fast on PDF and Autocad files? I already added the memory and there seems to be no change on speed. It really takes a couple of minutes before the file is printed. Thank you very much.
Mr Spock
03-19-2011, 12:40 PM
First which version of adobe. Second is it the speed to compile the job or the actual spool from computer to printer.
On adobe (in a pc environment) disable the postcript passthrou in the advanced features of the driver and select print as image. This may slow the compiling of the job but the print/spool time will be better.
pinoyprinter
03-20-2011, 01:30 AM
bh350 printing capability is not that fast in pdf, if you want ur files to be printed fast buy higher models like bh 420 or 500.
stevelau
03-20-2011, 10:00 AM
What is the memory of yr PC. The print speeds is also very much depend on the job sent from PC. If the job already sent to the printer, usually it will print in less then 1min.
