View Full Version : Error Code Di750 Error Code SC28-01
Printhead
03-19-2011, 10:33 PM
Hello everyone, I have a Di750 with error code SC28-01 can tell where to look to fix this code? Thanks
mtech
03-20-2011, 02:22 AM
28-01 The charging on/off operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging. (I can't stand the wording in some Minolta manuals!) I would check/clean the main charge. There is also a tech pub for 28-01 and gray copies. Clean toner control sensor board or replace it. 56AA-9100
Printhead
03-24-2011, 12:11 AM
Where do I find the main charge? Where is the toner sensor? Thanks mtech
Printhead
03-24-2011, 12:17 AM
Does the toner charging unit slide out behing the toner bottle?
mtech
03-24-2011, 04:45 AM
The main charge is located on the top of the drum unit and the sensor is located in the drum unit as well. The whole drum unit slides out from the front. You need to remove the brown cover and the unit is in back of that. Best of luck, be careful not to damage the drum when you get the unit out.
Rizwan
12-14-2011, 06:52 PM
Can an one plzzzzzzzzz tell me from where I can download service manual of konica Minolta Di750 i which all error code description is given plz email me at
rizwanfbd1@gmail.com
