View Full Version : need scanner driver bizhub 131f and 190F
djsayan
03-21-2011, 01:48 PM
hello dear friends
I have two machine bizhub 131f 190F and I was able to install the driver for the print but the scanner function to J have not been able to find the right driver or program, so if you like it helps me
acusso1234
03-21-2011, 03:57 PM
You can find it on the public site of konicaminolta. No available driver for windows 7, but you can use Vista driver instead of it (on a 32 bit system). during the installation you can find the location of the driver into the folder named c: konicaminolta\ GDI. The best way to use the scanner is to open MS word and choose aquire image from scanner.
djsayan
03-21-2011, 04:10 PM
thank you for your answer but I have a Windows xp and my chemain you give it does not exist "c: KonicaMinolta \ GDI" if you can give me the link to download the correct driver
acusso1234
03-21-2011, 04:22 PM
Online Services - Document Information (http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=93BD10A95CD8DE9BA6EA343139 3728C2.node01_02?path=../search.jsp&mode=show&document=236979)
djsayan
03-21-2011, 07:09 PM
the link that you pose does not work "Sorry, An error has occurred!"
fishleg
03-21-2011, 07:24 PM
Wow I was about to post the same thing I'm going to a customer tomorrow with exact same problem.
I have a PCL Twain driver but this doesnt work as it doesnt have a network card I think is the reason. I cant find the gdi drivers any where for it but I did find...
Bizhub 190f = Muratec 1950 mfx
You can get the Muratec driver but I haven't had chance to actually try it but it is the same machine so was just going to go there and try it. Maybe you could give it a shot and let me know first :P.
Drivers here for Muratec 1950
Customer Support-Drivers Download-MFX-1950 (http://www.e-muratec.com/ap/support/dr_mfx-1950.html)
Cheers,
Fishy
djsayan
03-21-2011, 07:44 PM
I have three machines in the same series I always look 190F Twain driver I'll test your suggestion. I want you to pass the PCL twain for testing too
acusso1234
03-21-2011, 09:36 PM
Bh130f come with standard GDI printer system that use the standard GDI driver. You can use Pcl driver only if the machine has the option Pcl board (IC901).
djsayan
03-21-2011, 09:50 PM
Can you explain more or give me more detail how this driver Instale
djsayan
03-23-2011, 11:33 AM
Cheers,
Fishy
solution for your dear friend its not working I test another type of driver he did not conresponde with the bizhub machine
djsayan
03-23-2011, 11:35 AM
there is a little thing I saw is that the diversity of its bizhub 130F walk with these two machines 131f/190f. it's bizarre that person is not the driver of the scanner machine :(:confused:
fishleg
03-23-2011, 11:12 PM
Mine works :P with the muratec driver. You have to untick hide incompatible drivers when you install it but it works.
djsayan
03-24-2011, 12:14 AM
Can you give me more details or the method for ressaye
