View Full Version : C552 Pink Background.
Imsdal
03-21-2011, 04:33 PM
8998I have this KM C552, the problem is where is supposed to be grey is pink, and after I calibrated it will remain ok for 4 or 5 days after that it will turn pink again.
I have change the PWB-EE Assy, and the magenta IU, i have even uppgrade the firmware to the latest B8 but no use. Just a couple of minutes ago my customer call telling me that the problem is back.
Now what is the next step.
i sent some examples. Nr 0 before calibration.
Sincerley
David M
ptrflrs
03-21-2011, 04:40 PM
Have you tried printing with a different driver and a different application when its doing that? I've had issues with different versions of cs3 and most adobe software.
BIG PAPA
03-21-2011, 04:42 PM
If you run all your halftones how do they look? Probably not a M problem, but one of the others that is not present. I would run all halftones, at full 255 then about 125, ans 75. See how they come out.
mo0651
03-23-2011, 03:02 PM
Look at sample #1 RGB black column. it should not be fading to pink. Not your magenta Iu acting up. It is the black fading off. Did the black IU dump? Whats The counters?
Imsdal
03-23-2011, 04:15 PM
No, it has not dump and the black has gone like 100k
krazeekidz3
03-23-2011, 10:14 PM
WOW, kinda sounds like my problem!!!
AjitN
03-24-2011, 04:00 AM
Hi
It looks like magenta in highlight is high. Red strip shows magenta instead of red, this is possible if yellow is low but green dows not show high cyan. This means magenta is high. Try adjusting magenta inhighlight mode in image quality adjustment.
Ajit
Imsdal
03-24-2011, 08:28 AM
I have change yellow, magenta and cyan IU and I did a calibration.
Now i wait and see what happen, i will come with info later on
David M
Imsdal
04-15-2011, 02:54 PM
Itīs seems that the problem were the I-units.
Itīhas been 3 weeks and my customer hasnīt call
David
holmis
04-15-2011, 05:06 PM
I had a similar problem with two new C452:s at a customer,a printed bannerphoto with a lake looked like kind of purple water.What i did was in service mode i redused magenta one step in highlight and did a calibration. I got my customer satisfied
najoor
03-17-2018, 10:52 AM
hi ,
print before stabilizer and 5 min after stabilizer image (service mode)= 39161 gery is pink
print after stabilizer image =39162 oK OK
Error p-21
help me
75-125-255
>>all test download
(http://uptoup.ir/uploads/guest/half.zip)
Synthohol
03-17-2018, 05:16 PM
the pic that ends with 0014 looks like a label is on the belt or under the xfer belt side bead or something, look in the upper right. what is that?
najoor
05-02-2018, 10:27 AM
hi, always Gets out developer magenta (after one week )
change megenta iu not fix
Phil B.
05-02-2018, 06:12 PM
hi ,
Error p-21
help me
75-125-255
>>all test download
SINCE the original poster has solved his problem
START A NEW THREAD OF YOUR OWN...stop 'piggybacking ' onto someone elses thread!
