View Full Version : Miscellaneous Bizhub 250 resets
Zesti
03-22-2011, 02:07 PM
Hi,
I've a Bizhub 250 machine. It works fine unless we use the ADF. It resets as if it has been initialized as soon as we press copy button. I've tried replacing DF but no use. Any help.
SmellsHot
03-22-2011, 03:55 PM
what happens if you hit start while making a copy off of the glass?
Have you reseated the adf connector?
BIG PAPA
03-22-2011, 04:22 PM
If you have swapped the whole ADF with same result I would inspect all the connecting wiring. Maybe pinched? Do you have the appropriate volatges at your pin outs on ADF board? If so, I would have to double check but I think ot runs off the MFBS board.
SmellsHot
03-22-2011, 05:09 PM
Hey Big Papa........your name sounds like you are trying to compensate for something .......... probably your SMALL Pen Cil.....haha
You like the sentence break? haha.....
tech51
03-22-2011, 05:36 PM
Hi,
Does it come up with an abort code? If it does it could be that the scanner lock on the left side of the copier is on. Turn it to the off position, that should cure it.
