View Full Version : 250ci background, *another one
jmaister
03-22-2011, 10:18 PM
full page, 2mm interval, very even.
Not drum, not charge, DLP? primary transfer roller?
the troubleshooting guide suggested tweak had no apparent effect.
edit:
2mm over 8 1/2" is about 215.9, divided by 2 is 107 ish. Guesstimating imaging process takes 1 sec for 30ppm machine, and 1 sec fro paper transport. That gives me about a frequency of the AC.
Assuming its AC, which component would cause that?
no, I tried to tell my doc I'm crazy. :D
and uh, springbreak, things are slow.
blackcat4866
03-22-2011, 11:49 PM
So, your image defect repeats at 2 mm intervals, or ~107 repetitions per page?
Well the drum will be ~95 mm intervals.
Primary charge will be ~38 mm intervals.
For starters, what colors are affected by your defect, in sim U089, Gray test patterns? Can you attach a scan?
I suspect that you've got a charge loss affecting mainly one color, and the source could be developing bias short or drum ground loss.
I doubt that it would be a drive problem because of the short interval. =^..^=
jmaister
03-22-2011, 11:51 PM
K DLP, and yes I believe its the bias as well.
Its electrical for sure.
*not on the site, I'm the phone support for this one.
blackcat4866
03-23-2011, 12:10 AM
I would try the black developing drive motor first, due to it's history of problems. Second choice, black developing unit. I would be nice if you had a scrap black developing unit that you could swap in for diagnostics.
You know the same motor is used elsewhere in the main drive. As a test you could switch the black developing drive motor with the black cleaning motor to see if you can change the defect.
