View Full Version : IC-408 Daig led stay on 29
If IC-408 daig led aways stay on 29,what problem of IC-408?
How to slove?
Marodon
03-25-2011, 12:19 AM
Hi,
If the 29 you refer to is on the green led display - on the top of IC-408, then it probably has crashed and you will need to reinstall the system software. System software disk (1 CD or DVD) should have shipped with IC-408.
Put the disk into laptop connected with X-over cable and follow on screen prompts. Make sure your laptop is on DHCP.
Hi,
I had been try reinstall the system software, but it's process in copy file to IC-408, the screen appear check network cable...... , put finish the screen close.
