View Full Version : C203 problem
backspace
03-25-2011, 03:17 PM
have a problem with bizhub C203. When printing machine works great, but when copying a problem occurs. when the image is scanned to the computer also the problem does not occur even when the scanned image to print release all is well.
90949093
http://www.copytechnet.com/forums/images/misc/pencil.png
Tom40
03-25-2011, 04:06 PM
It seems that PWB-MFP is faulty.
acusso1234
03-25-2011, 08:55 PM
When you make the copy how you set up the job? Do you use text, text and photo or photo?
RRodgers
03-26-2011, 12:51 AM
NEVER copy the test charts that come out of the machine. They NEVER look right and will throw you threw loops. Just be sure to clean the optics... do a reset and stablize and then calibration.
bigdcopy
03-26-2011, 11:00 PM
I agree with RRodgers don't copy the machine generated test prints they will lead you astray. Run stabilize/reset, and do the 3 gradation adjusts at least 3 times each as the book says most color problems are fixed with this method and as RR says don't forget the optics (they do get dirty) most of the other problems I have are because we are forced to reset counters for the image units and transfer belt instead of replacing them when time is up.
pepper38_cnd
03-27-2011, 01:59 PM
Make sure the customer hasn't gone into admin mode and changed the default copy settings. That would explain why it is only copying that you have the problem.
backspace
03-28-2011, 01:22 PM
The first thing I did is clean optics. Then I worked stabilization and initialization, calibration, but nothing. As for copying test charts .... the same is happening on any other page copied in color. I tried with FirmWare but nothing.
Imaging Units are almost new.
Today I appeared in code C4552 laser malfunction M
RRodgers
03-28-2011, 02:22 PM
Double check the scanner cable, although when that had a a bent pin you usually have a problem with yellow.
