View Full Version : Canon IR3300 Hard Disk Error e602 - 003
specialist_007
07-24-2007, 04:31 PM
Hi This is Suresh From India
I got IR3300 it shows the error message of e602 - 003,hard disk error,
I made diagnosis by pressing 1 and 9 at start,Still same Problem Continous!!
I need to reinstall hard disk , ,I Dont know the procedure,I dont have any manual for this will you please help to solve this problem, Please sent me the manual file , and service software to my mail ID : virgo_millenium@yahoo.com, , There is no service engineer support for this in our place,
Please do this favour
Thanking You
by
Suresh Kumar
India.
specialist_007
07-24-2007, 04:35 PM
I made diagnosis by pressing 1 and 9 at start,Still same Problem Continous!!I need to reinstall hard disk , ,I Dont know the procedure,I dont have any manual for this will you please help to solve this problem, Please sent me the manual file , and service software to my mail ID : virgo_millenium@yahoo.com, , There is no service engineer support for this in our place,
Suresh Kumar
India
canontech
07-27-2007, 10:22 AM
Hi Suresh,
I am a canon tech in australia, I thought I would let you know the details of your problem.
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Hope this helps......:D
specialist_007
07-30-2007, 05:50 PM
This is suresh From India,
Thank you very very much for your answer,
Yes ur correct my hard disk got problem,
I got system software for IR3300,SST
I got nethawk driver, The file is DMG file, How to extrract it??? how to install this driver?? please tell me the procedure? to connect via nethawk driver from PC to MAchine, I got centronics cable to connect, but i need the procedure,
is this nethawk driver is for this centronics cable ??
what is canon part number WM2-5230-000 ??
how it looks like, is it a one more board connected with motherboard(with small ram like chip)
please tell the procedure to install the driver and sent the software inside my machine
Copier_Guy
07-30-2007, 06:01 PM
CanonTech has told you the correct procedure except, you can use a "Centronics" cable to connect your PC or laptop to the 2200. If you have a printer port on the back of your PC, you don't need the NetHawk Driver. Just connect like you're conncting a printer. As he said before That's the easy part. You need to replace the HDD and then you need the 2200 system software to load into the SST. Once you get that, then you can begin the process of formatting the drive and then loading the system software.
Good Luck
Send me a private message and I might be able to swing something for you.
specialist_007
07-30-2007, 06:34 PM
I got the system software of 2200, and the printer is connected via a parallel port,
now how to connect the printer??
how can i check as it is connected??
specialist_007
07-30-2007, 06:41 PM
I got the SST Software!!
Printer is also connected via parallel port!!
now i need to format the hard disk ??
hard disk formatting is also in SST
i need to know how can i connect hard disk and make a hard disk format??
and i need the procedure to install the software inside hard disk??
i need to know how to push the file from pc to hard disk???
Copier_Guy
07-30-2007, 08:49 PM
Now that you have the software, you need to register the 2200 software into the SST. Open the SST and and select Register. Then to the right you'll see a drop down menu. From this Menu you'll need to select the software. Before you continue, is the system software in an .iso format? If so, you'll have to burn it to a CD for the SST to be able to access the software. It will not read the software in the .iso format from your PC.
specialist_007
07-31-2007, 07:27 AM
i got a canon system service cd for IR Series inside this i can see three folders first folder is named as IR2200,IR2200H, IR2200N (inside IR2200 there are five folders inside that are boot rom, hdformat, message, Rui,System.(inside boot rom folder there are two files (iR2200-XXxx0928-134F-BOOT.PRG and iR2200-XXxx0928-BOOT.ift) i dont know how to execute this files...and inside hdformat folder (iR2200-XXxx0007-HDFormat.ift) named file is there...and in other folders also .prg , .ift files are there , now how can i execute this files to my IR3300 machine hard disk,... the machine is connected via a parallel port, is there ant software to run this file from my PC to Machine,...??? please help me
Copier_Guy
07-31-2007, 02:55 PM
Let me know if the procedure I sent you works out. As Canontech said, the SST can sometime be tempermental, so if you get the Pink Screen of Death, don't worry. Just try again, by loading the patches seperately.
Good Luck
specialist_007
08-01-2007, 08:07 AM
No i cant find The registry firmware option in my System service cd, Please tell me how it will be???
Tell me which cd i got now
canon system service cd for IR Series inside this i can see three folders first folder is named as IR2200,IR2200H, IR2200N (inside IR2200 there are five folders inside that are boot rom, hdformat, message, Rui,System.(inside boot rom folder there are two files (iR2200-XXxx0928-134F-BOOT.PRG and iR2200-XXxx0928-BOOT.ift) i dont know how to execute this files...and inside hdformat folder (iR2200-XXxx0007-HDFormat.ift) named file is there...and in other folders also .prg , .ift files are there , now how can i execute this files to my IR3300 machine hard disk,... the machine is connected via a parallel port, is there ant software to run this file from my PC to Machine.
Copier_Guy
08-01-2007, 02:20 PM
You appear to have the correct software. Did you install the service support tool which is a separate software application? The only way you can use those system software files is through the use of the service support tool. Load the Service Support Tool on your PC and THEN you have to register the system software using the service support tool. Please follow the procedure I sent you through private message.
sivaji4me
01-17-2008, 04:01 PM
Could you please provide me the details of the software SST and where can i get it?
ap0203621
08-18-2008, 06:04 AM
E602-003,佳能机此代码表示硬盘系统出问题,解决方法只有换硬盘。本公司提供的硬盘接入打印机后便可使用,绝 对没有异常,目前发往全国各地的硬盘还未发现故障。如果客户机器已有打印模块,只需加我司的打印系统便可恢 复打印功能(外加100元)。如果客户机器没有打印模块,只需配备我司生产的ROM片和网卡,便可实现打印 功能(外加600元)。
我们主要提供IR 2200I、IR 2800I、IR 3300I、IR 3320I、IR 5000I、IR 6000I、IR 8500I的硬盘,价格如下:
Canon 机型基本配置 价格 加打印 ROM片及网卡
IR 2200I 硬盘+系统 500元 加100元 加600元
IR 2800I 硬盘+系统 500元 加100元 加600元
IR 3300I 硬盘+系统 500元 加100元 加600元
IR 3320I 硬盘+系统 800元 加100元 加600元
IR 5000I 硬盘+系统 500元 加100元 加600元
IR 6000I 硬盘+系统 600元 加100元 加600元
IR 8500I 硬盘+系统 850元 加100元 加600元
*本信息长年有效*
办公地址:深圳市福田区华强南路上步商业大厦西座201(市中医院斜对面)
办公电话:0755-81677725 83001919 林经理(大客户部)
办公QQ: 870530595 759835713 E-mail:zcdigi@hotmail.com
jajees
09-30-2008, 04:43 AM
SIVAJI THIS IS GEORGE FROM COIMBATORE , IF YOU CAN GET THE SST FOR CANON IR 210 SST ,PLEASE DO INFORM ME ALSO IAM IN SEARCHING FOR THAT .
GEORGE 098944 - 15000
info@globalforce.co.in
AIT MAMEUR
09-13-2009, 03:13 PM
i hope you have solved your problem, if it's ok, please send me the sst tool. i need them for my canon ir3300. thank you.
Ken111
10-06-2009, 12:23 AM
Does anyone have the SST Tool & software for CanonImagerunnerC3200?
Thanks in Advance...:)
Ken
mr patel
08-21-2010, 02:01 PM
call me
mr patel
08-21-2010, 02:03 PM
call me this problem solution 9892005951
mr patel
08-23-2010, 10:16 AM
contect 09892005951
