View Full Version : konica 7155/7165 problem
djsayan
04-04-2011, 11:39 AM
hello
konica 7155 machine has a problem we turn on the machine he asked Apelles sav SC36-02
7165 for the second machine it calls the code initializes the counter how the code or the Supreme
djsayan
04-05-2011, 12:14 AM
djsayan
04-06-2011, 12:27 PM
I have a machine konica 7165 it requires a code for the meter voltage
ineo+6501
04-06-2011, 12:33 PM
I think you need to use a better translator. We would help you if we knew what you were talking about.
djsayan
04-06-2011, 01:13 PM
I have a machine konica 7165 when I turn on the machine it asks me a code for the voltage meter, I do not known how this code then this code Supreme
ineo+6501
04-06-2011, 02:12 PM
I am guessing that you have just bought a 7165, and when you turn it on it asks for a password to allow you to use it?
If this is the case, it sounds like account track is turned on?
djsayan
04-06-2011, 02:25 PM
yes
djsayan
04-07-2011, 02:36 PM
up up up upu upu up
RRodgers
04-07-2011, 03:55 PM
hello
Goto kmbs.konicaminolta.com and grab the user manual for you machine, it's in there how to setup (or turn off) ECM.
djsayan
04-07-2011, 10:39 PM
I already have the manual machine, but nothing I found how to reset the code counter to walk to the machine
Morlock49
04-08-2011, 03:26 AM
down load the user manual and then goto section and pages 14-18 to 14-25. These pages describe how to make adjustments to account track. it is called ECM in the manual. try all zeros for the passwords. (default).
djsayan
04-08-2011, 11:09 AM
Can you give me the manual. mine it has ONLY 13-60 page til I not find page 14-18 14-25
jobert
04-08-2011, 02:49 PM
Follow this steps first or you may explore the ECM Setting menu.
Here's how....
1. Off the machine.
2. Press Help while you on the machine.
3. Input your 4-digit Key-Op password and press OK.
4. Press ECM
5. Input your 8-digit Master Key Code (try eight 0's or 12345678) and press OK.
6. Dissable ECM (Electronic Copy Monitor) by hitting off.
djsayan
04-08-2011, 02:54 PM
Here's how....
1. Off the machine.
4. Press ECM
thank you for your help but I do not have the code for this step''3. Enter your password 4 digit key-Op and press OK.''
jobert
04-08-2011, 03:10 PM
Try four 0's or 1234...
djsayan
04-08-2011, 03:19 PM
I have already tested the code but nothing. I think I need the reset to zero and mahine
jobert
04-08-2011, 03:27 PM
ah..w8 try 9272..
djsayan
04-08-2011, 03:36 PM
ah..w8 try 9272..
its not working
CraigW
04-08-2011, 04:24 PM
Hold 2 & 5 while powering and continue holding until selection screen appears. Select 6 "password setting" the master and the key-op password can be viewed.
djsayan
04-08-2011, 05:41 PM
thank you very much for your help
