View Full Version : Di 2510 cob47 code
fixthecopier
04-05-2011, 09:53 PM
The machine will maybe run a few, but mostly jams at exit in the bundle area. If I tell it to sort sets of 2, it will spit out 2 sets, then stop with set 3 in the exit rollers and show a jam or code cob47. I can clear that and then run 5 plain copies and all 5 will bunch up at the exit with the gate not open and not show a jam. I researched it and based on that I changed a gate solenoid that is behind the elevator, under the gate. This made no difference. Has anyone seen this before??
907tec
04-05-2011, 10:39 PM
I don't remember how or why, but I do remember seeing this code a lot in the past. For some reason, my brain associates the code with that little white "flapper" thing at the paper exit, in the finisher. I can't remember the actual part name, but it's that annoying little white spring-loaded arm that helps stack copies on exit. IIRC, you can just remove the piece entirely without any ill effects.
mo0651
04-05-2011, 10:40 PM
Timing is very critical in sort mode. There are some one way bearings behind the jam knobs at the exit. you have to remove the tray unit to get to the cover that they are behind. clean the bearings and scrub the shafts. I have only replaced a couple of those bearings, but have had this fix problem several times.
fixthecopier
04-05-2011, 11:29 PM
Thanks for the quick responses guys. I have dealt with the little white thing, and do not think it is that. Having had hundreds of these sorters in my area for years , I also do not think it is a bearing issue. Never had any sorter issues on these. I may rewrite the firmware. Not really understanding why it packs 5 sheets in the end with out showing a jam.
mo0651
04-06-2011, 09:02 PM
There are no paper present sensors near the orange rollers. So they don"t see the paper. You can pound your head all you want, but I would just go for those one-ways. worked every time.
fixthecopier
04-06-2011, 09:30 PM
I was hard headed, you were correct, I cleaned them and it worked. Thanks for the tip.
mo0651
04-07-2011, 02:25 PM
Went thru the same thing. 400 machines in area and 1 of these does it. 20 minute fix. After 2 1/2 days of head banging! lol
stevee104
11-04-2011, 04:49 PM
I am having the same problem , there is one oneway bearing on the shaft that is right behind the knob fn6
is there anymore that needs to be clean. the parts book list them as gears so i want to be sure i get them all.The part # for the one i saw was 4349-1633-01.
