View Full Version : Miscellaneous c250 print more ghost image
hello, anyone have facing this problem and any idea ? thank you
when you print a lot , problem will come out
see the attach
rprem
04-07-2011, 12:14 PM
it comes in any particular gsm board or in all boards
mrwho
04-07-2011, 12:42 PM
Simple things first:
- Are the fusing unit levers in the correct position (middle)?
- Is the transfer belt being cleaned correctly?
- Does it happen in all colors?
mo0651
04-07-2011, 02:23 PM
looks like black iu cant handle it. What have you done? A little more info? How old is IU?
IU still hv half bar , change other IU same problem
aleksander
04-08-2011, 04:29 AM
How about the image transfer belt and erase lamp? check them.
AjitN
04-10-2011, 04:10 AM
Hi
It may be checked in following order - Transfer belt ( actually cleanning blade performance or bad 1st transfer roll of black inside belt unit), dirty Erase Lamp, Bad Black IU & bad quality toner ( may be original but stored in hot place). It looks like charge on the black drum is getting diacharged.
best luck
Ajit
acusso1234
04-10-2011, 05:47 PM
Follow mrwho: fusing unit levers position.
