View Full Version : pro 1050
muhammad.imran
04-11-2011, 11:03 AM
hi
when i run drum potentail sensor adjustmet error2 appear
i replaced drum potentail sensor assebly but same
any body has face this problen or can help me out .
thank you
CT Copier Repair
04-11-2011, 01:41 PM
Drum good?
costel fasola
11-27-2014, 02:30 PM
is too much toner in developer . wrong setting
methogod
11-27-2014, 03:14 PM
i would change DV
also make sure drum potential sensor is connected well, can be loose bad wire...
you can usually get away with that error for a while, especially on a high production machine, if they are not huge on quality, and grey scale photos.
I have seen the DV unit cover not click on all the way so it just pumps toner dust into the process unit in about 30 seconds...
check your DV age, may be time to change developer. See if you can get a potential reading in I/o or the other way... this way you know if its the drum or sensor.
what brand of DRUM are you using? OEM or aftermarket?
