View Full Version : KMBH Pro C6500 firmware miss match with accessories and fiery ?
Desert Rat
04-15-2011, 03:35 AM
http://www.techsconnected.com/forum/images/smiles/pullhair.gif (javascript:emoticon(':pullhair'))
This install is turning into a marathon call.
I downloaded firmware for the fiery to the fiery, connected it to the
machine and it made a nice PS test page.
The fiery I have is the S450-04 model that sits on the floor. It sez "fiery"
on the front panel. It is white with black trim and has a door that covers
the pwr sw and CD drive.
Is this the IC305? I am not sure of what I have.
I hooked up the SD501 to the RU504 and then connected the
FS503 to the SD501. Nothing past the RU shows up on the
control panel.
The serial numbers have been inputted and the dip switches are in the
correct position.
I've been told I need the ISW tool to download firmware to the equipment
so all the firmwares in the accessories are compatible.
I also been told to just go direct to the machine with the thumb drive.
and I've heard the fiery is the problem
What am I missing?
DR
bizhub1
04-16-2011, 01:39 PM
Were these accessories previously installed on this 6500? Because they can go on the black and white high end models also, and their are jumpers that have to be changed. I have heard of the jumpers being in the wrong place and the output options not appearing on the panel. Don't think it has anything to do with the fiery. Also heard of people mixing up connectors on the relay unit and blowing numerous boards out. Their is a couple of plugs that sit close together and can get mixed up.
Desert Rat
04-16-2011, 09:28 PM
This unit came from a wholesaler. So it would be hard to say what these units were connected
to before this customer purchased them.
So far I don't believe I have crossed any connectors and the jumper plugs are not installed.
All the dip switches were in the C6500 configuration.
DR
bizhub1
04-17-2011, 01:46 PM
You should be able to just use a thumb drive for the firmware, i believe its version 60 on that model.
empiru
04-18-2011, 05:35 PM
We had the same problem with a Bizhub Pro C6500P, that had a PF601, FS503 (or 501) and a Relay Unit + Creo IC408. It worked fine; one day, we wanted to test a Fiery IC408 on the machine and guess what: The fiery didn't recognyze any Optionals (nor FS, PF or RU). I think it's possible that some Controllers don't recognyze some of the machine optionals.
Desert Rat
04-18-2011, 05:55 PM
empiru,
What fiery is the S450-04? And did that other IC408 keep the options from showing up on the
control panel?
DR
Desert Rat
04-18-2011, 06:20 PM
bizhub1,
Do you have instructions for downloading from the thumb drive or is there something in
the manual?
seniortech
04-18-2011, 06:45 PM
Updating the Firmware is shown in the service manual...
Desert Rat
04-18-2011, 07:09 PM
Ok, I'll give it a shot and see what happens.
DR
empiru
04-18-2011, 08:58 PM
DR,
I have no idea what kind of Fiery that is. My problem was, the optionals were appearing on the screen, but I just couldn't print - because the Fiery wasn't recognyzing the optionals.
Now I understand that your optionals don't appear on the screen... that's a tough one... I would try to change the firmware... see what happens - you can't do any harm
Desert Rat
04-19-2011, 12:27 AM
empiru,
What are the steps involved? I have the firmware and a thumb drive. I can open all the zip files
on the drive. Do I just plug it in and turn on the machine?
Have done this from just a thumb drive?
DR
pakalo
04-28-2011, 09:14 AM
Ciao,
Se il tuo Print Controller è un Midi Tower Bianco&Nero con display a 5 linee sul frontale e Materizzatore DVD Nero è di sicuro un:
EFI Fiery IC-303 (S450). Il suo System Op. è arrivato alla versione 3.0 (il Sys. Op. è lo stesso IDENTICO del suo successore IC-305)
Dopo la pubblicazione del Sys. Op. ver.: 3.0 sono anche uscite una dozzina di Patches della EFI che risolvono parecchi problemini.
Per aggiornare &/o rifare il Sys. Op. hai bisogno di 2 DVD: System Software EFI & User Software EFI, poi tutte le patches.
In Fiery IC-303 (IC-305) non ha bisogno di nessun settaggio per gestire completamente le C6500-C6501, le deve vedee e gestire completamente con la sua comunicazione bidirezionale. UNICO ACCESSORIO non gestio è il PB (Perfect Binder, è obbligatorio il CREO IC-304)
szhengpaper
04-28-2011, 10:24 AM
Szheng Paper Box Sdn Bhd Registered no.(ps/136787-p) is known for the Manufacturer and supply of best quality A4 copy paper, we supply mostly A3 paper A4 paper in roll and in ream 80gsm,75gsm.70gsm.You can request for the specification of all the below paper.brightness 100% which is good for all office use.We supply in major international markets and we are a trusted and dependable company to deal with because we render the best of services to our customers worldwide.We are a registered enterprise here and we operate with 100% return policy and delivery is 100% assured after you agree with our company dealing tools.
Contact us today for your order at our marketing Email :szhengpaper@rocketmail.com
A4 80GSM
Double A copier paper $0. 80
Paperone copier paper $0. 80
Golden Star copier paper $0. 80
Laser / Copier Paper $0. 80
Xerox multipurpose copy paper-- $0. 80
Mondi Rotritrim copy Paper-- $0. 80
offset paper-----------------$0. 90
A4 75GSM
Paperone copier paper $0. 70
Golden Star copier paper $0. 70
Laser / Copier Paper $0. 70
Laser / Copier Paper $0. 74
Xerox multipurpose copy paper-- $0.70
Mondi Rotritrim copy Paper-- $0. 70
offset paper-----------------$0. 80
A4 70GSM
Paperone copier paper $0. 65
Golden Star copier paper $0. 65
Laser / Copier Paper $0. 65
Xerox multipurpose copy paper-- $0.75
Mondi Rotritrim copy Paper-- $0. 75
Specifications:
Sheet Size:210mm x 297mm, International Size A4
Quality: Imported 100% Virgin Wood Pulp
Whiteness = 102-104%,Natural White
Capability: High Speed Copying100ppm, Laser
Capable,Inkjet Capable, Fax Capable.
Thickness: 103-110 um
Surface roughness TS ml/min: 75-175
Surface roughness BS ml/min: 100-200
Bending stiffness MD: >110 Mn
Bending stiffness CD: >50 Mn
CIE whiteness: 148-152
Cobb Test: 27-33 g/m2 27-33
KEY PERFORMANCE:
No jam in photocopy machine
No double feed
Stay flat after copying
Leave no dust in the copy-machine
Nice appearance-white and clean
Nice touch-smooth and bulky
No see through-print both sides
Been developed for : Photocopy Mac
NOTE: All price is in ( CIF ) means our company takes care of you shipping process to your port so the price includes paper cost ,shipment and insurance.
*Port of loading: Dickson sea Sabah,Malaysia
*Payment Term: L/C,T/T,WESTERN UNION
Minimum Order Quantity: One 20FCL (20ft Container Load)
Sample: Buyer pays for sample orders.
Delivery Time: Asia 14 working days,Europe 21 working days,America 24 working days and Africa 21 working days.
20FCL will be packed as minimum order quantity from our warehouse.
PACKING DETAILS:
500 Sheets per Ream
5 Reams per Box
1560 Boxes per container(With Pallet)
1600 Boxes Per container( Without Pallet)
7800 Reams Total in one 20FCL( With Pallet)
8000 Reams Total in one 20FCL( Without Pallet)
We look forward to receive your order confirmation and we hope to hear from you as soon as possible.
