View Full Version : KMBH C452 - Trouble Code C-255B
kizi57
04-17-2011, 09:16 AM
Hi
I have this trouble code in my bizhub c452, i open and close the lower front door, then the trouble dispappear.
What could be the couse of such a problem?
Zeldaman
04-17-2011, 11:54 AM
Hi there!
Problem of the drummotor BK: could be a bad motor (often in K-M machines!) or the PCU is bad. You should check if it´s correct assembled.
Greetings...
bizhub1
04-17-2011, 01:34 PM
I believe that code is the yellow TCR sensor. Check the yellow I/U unit
JustManuals
04-17-2011, 09:41 PM
Just Manuals | The Internet's largest selection of manuals | Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
Mr Spock
04-18-2011, 05:10 AM
C255B: Yellow TCR sensor adjustment failure
reinstall iu
change iu
check icp's on the prcb
replace the prcb
Zeldaman
04-18-2011, 07:59 AM
Hi there!
Is there a new version of the field-manual? Mine said c-255b: drummotor BK failed to turn.
Greetings...
bizhub1
04-18-2011, 03:42 PM
Hi there!
Greetings...
In my manual, a C-225b is the drum motor
kizi57
04-18-2011, 05:00 PM
the error appeared once, then it did not appear at all. is that means the error still remaingin in machine? or the error is cleared?
emujo
04-18-2011, 08:43 PM
From the knowledge base:
Description:
C225B error code.
Solution:
PROBABLE CAUSES:
Shortly after power up
Black drum motor (M18) or PRCB has failed.
Check the M18 connector for proper connection and ensure that M18 has proper drive coupling. If CN13 on the PRCB is connected securely (CN35 for bizhub C452/C552/C552DS/C652/C652DS) and the error reoccurs, replace M18 (p/n A00J M110 00) and the PRCB (PWB-MC) as a set.
bizhub C451/C550/C650 - PRCB (p/n A00J H001 06)
bizhub C452/C552/C552DS/C652/C652DS - PRCB (p/n A0P0 H001 01)
Note: If a new M18 is not available, replace the Main Drive Unit (p\n A00J R704 00 for bizhub C451/C550/C650 and p/n A0P0 R707 00 for bizhub C452/C552/C552DS/C652/C652DS).
Intermittently when coming out of Power Save mode
The DC Power Supply (DCPU) is failing.
Replace the DCPU (p/n A00J M404 05 for bizhub C451/C550/C650 and p/n A0P0 R704 11 for bizhub C452/C552/C552DS/C652/C652DS).
If you're a KM tech you should be ashamed for having to ask for this info. If not you should be placing a service call to get this taken care of. Emujo
fixthecopier
04-18-2011, 09:24 PM
If it is not displayed on your screen, it is cleared. Sounds like the pcu was in a bind and freed itself up
Mr Spock
04-19-2011, 01:13 AM
The post stated c-255b which is the yellow toner sensor.
kizi57
04-19-2011, 04:08 AM
thank you guys...
i'm end user, and in my country (east africa, Tanzania) we have lack of KM Technicians and Consumables so this is why i've decided to register on this website in order to have technical assistance! Would also like to ask if you know where i can buy toners, iU and other consumable at a competitive price.
Micro Office Solutions
07-18-2012, 09:41 AM
Description:
C225B error code.
Solution:
PROBABLE CAUSES:
How you doing Emujo?
if i may ask, where did you find that on the knowledge base and which one? Ours is not that up to date and doesnt have that info in it.
Thanx!
07-18-2012, 09:45 AM
thank you guys...
Hi Kizi
What consumables are you looking for and for which machines?
blackcat4866
07-18-2012, 06:20 PM
I think you may have looked up C-225B, Zeldaman.
Personally, I'm thinking that the yellow developer is probably failing. If the code returns replace the yellow imaging unit. =^..^=
MRK23
07-21-2012, 03:21 AM
Check the toner density level in The State Confirm in the tech rep mode. Then select level history 1, toner density should alway be arount 7%...If it is below, enter image adjust and select manual add toner and select Y...after complete check level history again...now yellow should be at or just above 7%...If not, you may have a toner motor that has failed or a printer control board that is failing to turn on the motor. Just had to go through that process with the cyan and black toner motor not turning on for a C452 and it turning out to be the printer control board. A brand new machine out of the box...
kizi57
09-07-2012, 10:15 AM
Hi all,
the problem came again, and this time it is very serious, there is also p-31 trouble code with my unit, there is black color shift on some of the prints, black color does not register on its position.
i heard it might be PRCB or DCPUneed to be changed, also M18. as i told you before i'm not KM Tech, i need help how to resolve this?
Microoffice
11-16-2012, 07:27 AM
Hi all,
Hi Kizi
Please will you tell me if you managed to get this problem resolved? i have had the exact same problem for months now, can't find the solution. i would really appreciate your feedback!
Thanx!
kizi57
11-16-2012, 07:44 AM
Hi Kizi
Thanx!
I manage to solve the problem. I with my technician, open back side of the unit, then we clean the sensors. Look at your service manual will help you out...!
Microoffice
11-16-2012, 07:50 AM
[QUOTE=kizi57;324346]I manage to solve the problem. I with my technician, open back side of the unit, then we clean the sensors. Look at your service manual will help you out...![/QUOTE
Did you replace anything? PSU? PRCB?
kizi57
11-16-2012, 08:55 AM
nothing to replace... follow your service manual will help
microofficesoultions
11-16-2012, 09:14 AM
[QUOTE=Microoffice;324348]nothing to replace... follow your service manual will helpMy friend, I've been a senior technician for over 10 years now, I've gone through the manual on numerous occasions. Unfortuantely I'm the only technician in my company, otherwise I would've asked for assistance. I do understand that you are only the end user, and the easiest thing to say is "check the manual", but that is why we have this site, so that technicians and engineers can help and assist each other when all else fails and the manual doesn't help anymore.But thanx for trying to help, I really appreciate it. God bless!
remati
11-17-2012, 12:41 PM
Hi
I regret to inform but at the final...you´ll must have to replace the entire mecanical drive unit....(one piece)..you will need a feww houres to do it....
Mr. Joshua
11-20-2012, 07:42 PM
For what it's worth, on my first and only experience with this code, it was the DCPU. I was able to get the machine to code more than 50% of the time as it was coming out of power save mode.
I replaced the DCPU and soon after the code returned. Now I'm nervous, thinking I've wasted a DCPU and I took a long time to make that call in the first place. Long story short, 1st replacement DCPU was at fault too, replacing it again fixed the problem.
