scoobysteve
04-20-2011, 05:41 AM
I havent had a good run with these lexmarks so far - about 80% fault rate so far. Anyhow, not sure if this is a machine issue or a client induced one.
I have gone via the web interface for the machine and i have clicked on "Fax Settings" in the "Settings" as well as the "Links & Index" links in the left column, however i do not have an option to select which fax mode the machine is to use, ie no option to choose "Analog" or "Fax Server". All i get is a link named "Fax Server Setup"- no "Fax analog setup" link like 3 other model i have checked with.
I've done firmware to the latest.
Could it be security settings or something like that? any suggestions would be much appreciated. Thanks in advance.
