I have a bizhub c351 that will not allow me to switch from dhcp to static. The manual button is not listed in the tcp/ip menu. Any ideas? I do have network connection. On DHCP its pulling a 172.17.249.2 ip. I have tried to push all buttons. The printer makes a beep and does not allow me to edit ip/subnet/default gateway. Any help will be appreciated.
Bizhub c351 Network question
I have a bizhub c351 that will not allow me to switch from dhcp to static. The manual button is not listed in the tcp/ip menu. Any ideas? I do have network connection. On DHCP its pulling a 172.17.249.2 ip. I have tried to push all buttons. The printer makes a beep and does not allow me to edit ip/subnet/default gateway. Any help will be appreciated.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
Firmware is only available for KM authorized technicians.
You don't happen to have a Fiery on the machine, do you?
Try doing a data clear in service mode, this will reset to defaults and you should be able to change it.Comment
If all fails put your laptop on the same IP range and log into the web browser with a cross over cable. Log in as administrator and see if you can change the settings under network settings....Comment
The bottom RJ45 is for the machine NIC. Go to service mode, option board status, set to controller 0, exit and restart. Now try with cross over. I think the top one is with Fiery installed, this way you disable the Fiery and enable the machine NIC.Comment
Found option board status its under system 2. However the options under. there do not allow me to change to a zero. Here are the options: fax(main) the options are set and unset then fax sub set and unset then local i/f set and unset and jpeg set and unset. fyi i performed the data reset by hold ing down the utility key on start up. Still unable to connect by lan cable via laptop. The laptop is recognizing the nic but is not showing up using an arp -a command. it will allow me to connect via internet explorerComment
Trying to find out whether you have a Fiery installed on the machine - if you press utility is there a "controller detail' button in the right top of the LCD display?Comment
Trying to find out whether you have a Fiery installed & enabled. If you press "utility" button is there a "controller detail" in the right hand side top corner of the LCD display?Comment
