View Full Version : Miscellaneous Bizhub C350 Service Mode
tmanamore
04-20-2011, 07:53 PM
How do i get into the service mode on a Konica Minolte Bizhub C350?
Valeo175
04-20-2011, 08:09 PM
Hit the stop 0-0 stop 0 -1
tmanamore
04-20-2011, 08:12 PM
That didn't work. Anything else I can try?
CT Copier Repair
04-20-2011, 08:25 PM
Yea don;t post this stuff in the publicly viewed areas
send it via private message
pakalo
04-28-2011, 08:52 AM
Ciao,
Per entrare nel Tech. Rep. Mode premere:
Utility->Contatore->Stop->0->0->Stop->0->1
Per il TROUBLE continuare da qui premendo:
Stop->9->Stop->0->Stop->1
Ciao.
da2or
05-03-2011, 08:42 PM
I'm having the same issue. Unable to get into service mode due to error c-d010. I must be missing something as I have tried a few things to get in to service. I cannot get past the first screen, so I'm looking for a power up solution! Thanks, if you can help!
CT Copier Repair
05-03-2011, 10:49 PM
I guess that if we can't read italian its ok
DOn't post this in forums
come on guys its not that difficult
B
da2or
05-03-2011, 11:34 PM
My problem is when I power up with the utility key held for a Trouble Reset and I enter in my service code, I see the flash of the CE Service password screen, but then it returns to the error screen before I can enter in the password. So I am having a tough time just getting in. Anyone have any suggestions? Thanks
tritwi
05-06-2011, 09:15 PM
Hit Utility key then counter then counter details then stop 00 stop 01
chrisban35
08-14-2015, 07:52 PM
Now that I am in, what is the password? I'm normally a Canon and Xerox tech, so need some help guys. Thanks in advance.
khattab.al.masry
08-16-2015, 08:49 AM
Try with the following attachment if password wrong use another 12345678.
with my best wishes.
chrisban35
08-16-2015, 06:14 PM
Thank you very much for that information... ;) I actually fumbled around online for a while, and came across a site that used the following... Not sure why it worked, but it did... :)
"1. Press the Utility/Counter key.
2.The Utility Mode screen will appear.
3. Touch Meter Count on meter count display.
4. Press the following keys in this order.
Stop a0 a0 aStop a0 a1
5. Touch Password, and enter the CE password using the display keyboard or the 10-key pad.
Note: The initial setting for CE password is “92729272”. "
I have never seen this code before, but it worked.. :)
Thanks again for the pdf, I've saved it to my service records.
