View Full Version : SLOW PRINTING WITH pdf. B 350
Hi All
Our It Engineer Came Across A Problem The Other Day On A Bizhub 350 , Problem Being , When Printing Through Pdf The Machine Prints Very Slow On Al Other Applications (word,exel.etc) It Prints Normal The Problem Is Only With Pdf.
TonerMonkey
08-04-2007, 01:53 AM
Try using the postscript driver - are you using PCL cos it sounds like your customer may be ?
Scott_Lewis
08-04-2007, 07:04 AM
Make sure the Adobe Reader doesn't have the 'print as image' selected. This will slow printing by about a 20:1 factor.
Thanks A Lot Guys , I Will Give The Info Through To Him And Get Back To You .
random
08-07-2007, 08:03 AM
If so there is one specific patch that needs to go on LAST.
skirt_chaser
08-08-2007, 05:04 PM
Is there a postscript chip option that can be installed on the print board ?
TonerMonkey
08-08-2007, 09:56 PM
With all due respect, in addition to the previous comments:
It would be a colour C350 if it were to have a Fiery and it's only older Konica products that have a PostScript chip fitted to the NIC.
Thanks for your input guys.
random
08-09-2007, 06:47 AM
Sorry half reader - I will check with our tech he has bound to have struck this.
AusiTech
08-09-2007, 09:30 AM
Where in reader ?? file print? or in document?
cheers
random
08-09-2007, 08:37 PM
Usually on the bottom left of the print dialog (not in properties)
http://www.copytechnet.com/forums/attachment.php?attachmentid=90&stc=1&d=1186688240
Scott_Lewis
08-11-2007, 06:55 AM
Thanks, Random.
That was done so nicely.:D:cool:
random
08-11-2007, 10:33 PM
Watch for PDF's that are scans rather than acrobat documents. These are images and regardless of if print as image is selected or not it will print slowly as each page IS and image rather than just text.
Not being able to select text is dead give away it is an scanned image.
AusiTech
08-15-2007, 11:46 AM
Cool thanks Random. Sorry for delay been on hols.
konisolver
10-05-2007, 06:45 AM
Upgrade the unit to ver 70 then make sure to select printer in the user mode instead of copier. This will make it print much faster.
Juggy
10-08-2007, 07:52 PM
what kind of pdf version is printed. Version 1.5 / 1.6 or 1.7. If version 1.5 and down is used download pdf direct print utility from the konica minolta site and try printing pdf. you dont need any pdf viewer or software to print. Just right click the file needed to print select pdf direct print and its atleast 5 times faster than any other software printing
