View Full Version : bizhubpro c6501
thuo
04-24-2011, 03:15 PM
Hi,
have bizhub c 6501 warms up o.k. but from there does not come ready keeps on displaying stabilizing. new imaging units & transfer belt.any guess what could be the problem with the machine.doesnt display any error code.
thanks
CT Copier Repair
04-24-2011, 08:55 PM
Firmware
or setup problem ie when new image units and or developer were replaced they were not set up correctly
but i'd try firmware first
thuo
04-25-2011, 11:45 AM
Firmware
machine was working working o.k after replacing the parts .problem is keeps on running (stabilizing ) forever.any failure in related parts like transfer belt or pgc sensors.
engineer
06-21-2011, 04:06 PM
is in display still "warming up"?
1FRY1
06-21-2011, 11:50 PM
If it says "warmimg up" all the time then one of the three upper heater lamps has gone
check each one
thuo
06-22-2011, 07:08 PM
Hi all
thanks for you suggestions.problem was neither firmware or fuser unit related.
it was a malfunction of a pulse sensor
thanks
Jsh77
08-19-2011, 05:28 PM
Try to change:
65AA 5365 1 FIXING LIMITTER
A03U 7256 00 Fixing Regulating Shaft /A
I had a similar problem, machine was in warming up mode for a long time. Limitter was slipping...
