pcb0960
01-28-2005, 07:26 AM
hi, I have a problem with the doc feeder skewing
slightly I think I figured it out it has to do with the metal bar, or the plastic turn guide right before the metal plate (hope I am describing this correctly) also the machine then started feeding two sheets when only one is in the feeder, I think that was because the machine was under a flourescent light. now this machine is not copying off the glass, but it will start feeding from the feeder without paper
in the feeder.....TIA Patricia
