View Full Version : Web Scope login error
Green Hornet
04-28-2011, 09:04 PM
When attempting to login as admin to one of my copiers I recieved the following error:
Cannot perform service.[Sub Switch is OFF]
Any ideas?:confused:
Thanks.
RRodgers
04-28-2011, 10:29 PM
Thanks.
Does it have a stuck print or fax job? Is the memory at 100%
mo0651
04-28-2011, 10:47 PM
is it on?
Green Hornet
04-28-2011, 10:51 PM
RRodgers -
Fax function is disabled and there are no jobs in the queue. The machine has been rebooted several times. I can successfully ping the machine. I've successfully logged into Web Scope for this machine as admin before.
Thanks for the quick reply.
Green Hornet
04-28-2011, 10:55 PM
is it on?
It's on and I can get into Web Scope public access. The issue is only when trying to log in as admin.
RRodgers
04-28-2011, 10:58 PM
IE or Firefox? Try Firefox.
Green Hornet
04-28-2011, 11:29 PM
Unfortunately FF is not an option for me here at work. I manage about 110 Konica's though and log into all the others through IE with no problem. I've even logged into this very machine, from IE, as recently as last week with no issue.
It's a bit of a head scratcher. If I haven't come up with a solution by tomorrow I'll have to call in a service tech.
RRodgers
04-28-2011, 11:44 PM
IE is ALWAYS a problem for me, if you can, can you try opera maybe?
Maybe try clearing your browser cache (on IE) and see if that helps.
Green Hornet
04-28-2011, 11:59 PM
Well, I cleared the cache, and I'm in!
Thanks for the suggestion RR.
aleksander
05-03-2011, 03:25 AM
check the firmware, try to rewrite it.
