View Full Version : BizHub 250 IU
copyman
05-02-2011, 12:20 AM
Can I take an Image Unit with 26k from one machine and put it in another with the "replace IU message"? If this can be done what else has to be done before resetting life counter to get rid of message on display?
Thanks in advance
perdana
05-02-2011, 03:01 AM
No. you can not. You must change Pico fuse inside IU conector.
copyman
05-02-2011, 03:53 AM
I don't think this image unit has a fuse? I know the "di" 250 does
perdana
05-02-2011, 04:19 AM
Yes, Copyman right, Bizhub doesn't have fuse. You only disable the indicator before they shown by setting Software Sw.
you can reset the counter from techrep mode , but must change drum and developer , do F8
fixthecopier
05-02-2011, 10:56 AM
to turn off the message go to soft switch settings,enter 418 for the mode or top number, the change bit 3 to a 0 and reboot the main power.
tech51
05-02-2011, 04:31 PM
Thanks in advance
Is this a C250 (colour) or a BZ250 (b/w)? Only reason I ask is that the BZ250 messages "change pc drum", whereas the colour machine says "replace IU". Please clarify the machine type to get the correct advice...
