Bizhub C5501 - default Black Copying
  • MFPTech
    • 486
    Is it possible to set Black as default for copying please?
    Normally this is under user features but could not find "Use Current Settings" on this model.
    Any help will be appreciated!
  • bizhub1
    • Sep 2008
    • 230
    To set the machine to default to black for copy mode, perform the following:
    1. Press the Utility Button.
    2. Select User Setting.
    3. Select Initial Setting.
    4. Select Copier Initial Setting.
    5. For Color mode select Black.
    6. Make any other desired initial settings.
    7. Select OK.
    8. Select Close.
    9. Select System Setting.
    10. Select Reset Setting.
    11. Set Mode Reset Setting to Initialize.
    12. Exit User mode.
