Di470 is displaying error code C-143E
  • delosangeles
    • May 2008
    • 274
    [Error Code] Di470 is displaying error code C-143E
    Hello everyone. I am working on a clients Konica Minolta Di470 since I have little experience on this line I have no idea what to look for. I would appreciate ever ones input. Thanks.
    Trade like a tiger sleep like a baby
  • BlueBlazer
    • 25
    Manual says - "C143E EDH Trouble"
    • minimerlin
      • 851
      That code is caused by the EDH Takeup tray operations!! Maybe user has bounced the unit back when they opened it, or dumped a stack of paper onto it. Sometimes you can reset it by cycling the front door! If not check the area of the tray lift motor (at rear of unit) and make sure that the silver metal actuator is not bent. It is a long time since I worked on these units but used to get the code a lot. I think there was an update from KM on this problem I will look to see if I can find it.
      Please do not PM me without asking first.
      • delosangeles
        • May 2008
        • 274
        Thank you both kindly that info really helps, you guys are great.
        • minimerlin
          • 851
          C143E Details
          This shows the actuator plate I was talking about! Hope it makes sense!
          • copyman1
            Re: Di470 is displaying error code C-143E
            Cycling the front doors helped me to clear the code, thanks!
            • 907tec
              • 434
              This code happens pretty regularly on my 450's and 470's. As others have said, cycling the front door usually clears it. Every once in a while I will get an especially persistent code, requiring me to turn off the machine and restart it with the EDH unplugged. After it boots up, turn it off and restart it again with the EDH plugged in. Can't say why it works, but it does.
