View Full Version : Miscellaneous Konica C450 with Fiery - Weird configuration issues
fissionchips
05-10-2011, 06:55 PM
So, when trying to run network controller configuration on a C450 with an attached Fiery, I get the strangest behavior. I select Controller Details > Menu > Run Setup and it asks if i want to "continue setup", I select yes, and the machine times out back to the regular menu. I have to attempt this 10 or 12 times before I actually allows me to login. Even then, I try all the possible passwords, including Fiery.1, 00000000 and 12345678 and none work. After 3 failed attempts it reboots the fiery controller and I have to go back in again. Anyone have experience dealing with this interface?
emujo
05-10-2011, 07:02 PM
Just had a similar issue on a C450..Couldn't get past the Fiery Admin password..tried all the normal ones...tried a firmware update (it was at a very low version) and after a C-E002 (expected) and a HDD version up all went well (default Fiery password worked) Emujo
fissionchips
05-10-2011, 07:11 PM
Awesome info! Thanks for the quick response. I will try this and see what happens. Did you replace the HDD?
emujo
05-10-2011, 07:12 PM
No, just firmware version K0. Emujo
