View Full Version : canon iR 3530
willy brown
08-13-2007, 03:18 PM
I Am Trying To Laod The Software On The Ir 3530 Canon Copier. I Have Every Thing That Is Needed. When I Start The Process It Gives An Error E200 In The Sst Service Support Tool Box.
The Error Is: Could Not Connect Within The Timelimit
File Name:- Targetinfo.txt.
Regars To All
Copier_Guy
08-14-2007, 12:38 AM
It sounds like your PC is not connecting to the iR3530. Check your connection and try again. Make sure you're using a cross over cable if you're connecting via Cat5. Make sure you boot up in download mode: Hold down the 2&8 Keys while turning on the power. Also make sure your PC's IP address is set to 127.16.0.101, 255.255.255.0, then try to connect.
willy brown
08-20-2007, 11:35 AM
thanks for the earler advise. but after loading the system software the LCD is black. I checked in the service mode for RAM it shows 0 (zero) Ram. I've tried another Ram But still the some. what can I do. is there a way of resetting the whole system?
Regards
willybrown
Copier_Guy
08-20-2007, 02:22 PM
What you did by reloading the system software was pretty much a total redo of the software. When you did your reload, did you select "ALL", which is a HDD Format and also a reload/upgrade of the various system BIOS versions? i.e.; D-CON, M-CON, R-CON... If you did all these things and you're getting the indications you explained, you may have a faulty Main Controller or LVPS that supplies the operating voltage to your Main controller.
willy brown
08-23-2007, 11:11 AM
Sorry I did finish on the RAM. As i was saying. when i put the expansion RAM in the machine it hangs up. What am trying to do is upgrade it to 512 from 256. The other thing is, will the S1 finisher work without upgreding the iR 3530.
Copier_Guy
08-23-2007, 07:01 PM
Are you using the correct RAM Chips? You might have a set of bad ones. Does the machine still act funky when you install just the original chip it came with? Also, if you're putting in just one chip, make sure it's installed in the top slot. Let me know.
Good Luck
panalkar
08-31-2007, 07:30 AM
Just check with 256 mb RAM
Copier_Guy
09-05-2007, 02:50 AM
Just curious as to how you made out with this problem. Also, the S1 finisher should work without you having to upgrade the machine.
Let us know how you made out.
parimalj
10-22-2014, 05:16 AM
Hi,
Could you please provide me with the service support tool as I dnt have it and also the file required for the hard drive?
My email is parimaljoshi5@gmail.com
